TwinTurbo.NET: Nissan 300ZX forum - turn the EBC off and see if the problem goes away
itsghoZt
on May 11, 2008 at 8:18 AM
Boost issues with Greddy Profec Type-S
posted by Nismoz3255 (Albany)
on May 06, 2008 at 06:54 PM
if not you either have boost jets still installed, EBC hooked up wrong, clogged / busted wastegates that are stuck shut, im sure other will chime in with more help..
p.s. Are the stock boost solenoids still installed?
Nismoz3255 (Albany)
18:54:15 05/06/08
If you have sport 500's..... The wastegates open at 12psi
Josef(Houston)
18:04:17 05/07/08
Re: If you have sport 500's..... The wastegates open at 12ps
Nismoz3255 (Albany)
09:15:24 05/08/08
Just to be sure, but you did REMOVE the boost jets right?
Josef(Houston)
00:09:45 05/09/08
Re: Just to be sure, but you did REMOVE the boost jets right
Nismoz3255 (Albany)
09:31:14 05/09/08
turn the EBC off and see if the problem goes away -
itsghoZt
08:18:06 05/11/08
